Upgradeable product designs for the Prop II
I was thinking about the PropScope over the weekend. I need an oscilloscope and getting an "open" system that this group is expanding would be a big plus but reading several of the threads, it sounds like it will max out the Prop. I assume the cost of the PropScope is mostly in the electronics -the Prop chip is a minor part of the cost. That got me thinking... Do we know enough today about the Prop II today to build an upgradeable product? If we could swap out the controller when the Prop II becomes available and get something like 16X the power...
What would be the best way to upgrade Props in the future?
What could we do with today's designs·to make it easier?
Power supply? Carrier board? Clock design? Space requirements?
I think the only things that can be planned for are:
1) The I/O pins will be 3.3V logic, so existing 3.3V logic interfaces should be fine
2) The highest supply voltage will be 3.3V and there will have to be another regulated supply, probably 1.8V
3) There will be some crystal normally used for clock generation, probably similar to the current crystal
4) The chip will be larger and will be in a larger, surface mount only package
The Propeller II chip will have approximately 100 pins ;·25 on a side in a QFP style package. ...So the Propeller II will not be a drop-in replacement for the Propeller I. Even further, the Propeller II will require 1.8V and 3.3V supplies. With the exception of feature enhancements and added functionality, what should remain the same for most circumstances is the software that you are currently programming the Propeller I with.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/1/2008 10:07:17 PM GMT
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
But I assure you we'd have a QFP chip package. It's a production necessity and a preference over QFNs based on our sales history, manufacturing experience, and ease of design-in.
These designs evolve until they are complete. And Chip doesn't release anything until it has met his expectations. This means that certain aspects may continue to evolve in either direction beyond what has been discussed in these forums.
I already have a design for a new SpinStudio based on the current Propeller. It's what I consider my next logical step. It's mostly surface mount parts. When Propeller II comes, my SpinStudio mainboard for it will look very similar to this, except there will be 8 ports, 2 per side of the square instead of the current 1 per side arrangement.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Yes sir!
Beau Schwabe
IC Layout Engineer
