PIR Cheat to detect stationary human?
Can you stick a Parallax PIR sensor on a servo and cause it to rotate back and forth to detect
a stationary target or would the change in background heat cause too much noise to get a
correct reading?
I'm looking to detect a person only about 2 feet away.
correct reading?
Jax
If a robot has a screw then it must be romoved and hacked into..
Frankly, I think Ugha's suggestion is at least worth an experiment. The detector's sensitivity to stationary heat sources versus the amount of radial deflection, along with the prevalence of false positives, is certainly worth quantifying.
Jax
Jax
SRLM: Some of those IR thermometers can be quite costly. If it's possible to make a "people detector" using a $8-10 sensor,
that'd be very useful. [noparse]:)[/noparse]
GWJax: I'd appreciate it if you could play around with it like you suggested. I don't happen to have any standard servos and
returning to original position with a cont. rotation servo is a pain in the... well you know.
You’re right it is worth looking into…however I will add that in my experience any movement seems to trigger the device. Here is why, and a possible work-around. The Fresnel lens on the device gives it a roughly 180 degree view. Not quite, but trust me…it has a wide field of view. The lens focuses the thermal energy onto a set of sensors inside. These kind of resemble a CCD. In any event there is an analog circuit that creates a kind of electrical balance based on the heat patterns seen. This circuit allows for slow changes, but as soon as you move the unit a little bit it makes a big change on the small element inside and the circuit goes out of balance.
Now, a possible work-around might be to restrict the field of view so that the PIR only sees a narrow field of view ahead. This would result in less overall motion and require a bigger change in IR for the elements to see. Of course, a good scientist will try it both ways, but ultimately that is where I see this going if it is to work. I hope this helps. Take care.
Parallax Engineering
GreenLight: Did you cover the entire white lens or just parts to make it more directional? Did you try any other materials?
I will have to give this a try
I have one thing to ask what would be the best thing to use to restrict the field of view
··Thanks for any·
Sam
I tried half of an IR LED shield over the sensor (the half that is a tube) but it didn't significantly change anything. I have yet to try a reflector of some kind.
One thing that would destroy the system is any sort of electronics (computers). My body only registered at 19 Celsius, but my monitor came out very reliably at 27 Celsius. So (with either the IR thermometer or the PIR) you'll have to make sure that you don't point it toward non-human high temperature devices.
On a side note, I noticed something interesting about the IR thermometer operation. When I placed it over a heat source (my heart in this case) and in very close proximity, then quickly pulled it away about 2 inches and pushed it back, the measured temperature shot up about 5 degrees, then fell back to what it was before. Any ideas on why this is? The closest thing that I can relate it to is possibly a Doppler shift, but I don't think I moved it that quickly...
Post Edited (SRLM) : 12/3/2008 4:45:37 AM GMT
http://www.scary-terry.com/itw/pirsensor/pirsensor.htm
http://techartblog.blogspot.com/2007/08/parallax-pir-sensors.html
