PLease, make it start. ** Problem solved ** — Parallax Forums
PliersPliers Posts: 280
edited 2008-12-01 23:36 in Propeller 1
First let me say I enjoy reading this forum. You guys are great.
I really do try to figure this stuff out on my own.
On to my situation… I have a PPD board.
I’m using a scope, so I can watch my input and output pins.
If I comment out the waitpeq, I can see P0 pulse high.
Where did I go wrong?
   PUB IOTEST
   cognew(@IO_TEST, 0)
  DAT
    ORG 0
    IO_TEST
   MOV DIRA, #%0001        'Set PO as output
   waitpeq %0000, %0100    ' wait for P2 to go low
   MOV Outa, #1            ' Pulse P0 high
   MOV Outa, #0
  cogid     temp
  cogstop   temp
 temp  long   0
Post Edited (Pliers) : 12/1/2008 2:33:37 PM GMT
  • nutsonnutson Posts: 242
    edited 2008-12-01 13:33
    Manual page 412: WAITPEQ State, <#>mask
    You have the target state in register 0, and the mask in register %0100 ??
    Pulses from code that executes once ?? Try putting a JMP at the end to make the code loop back.
  • PliersPliers Posts: 280
    edited 2008-12-01 14:30
    Thank you very much nutson for the code.
    WAITPEQ data, mask
    data LONG %000
    mask LONG %100
    Post Edited (Pliers) : 12/1/2008 2:41:37 PM GMT
    edited 2008-12-01 14:46
    Could somebody tell me what I'm missing in my understanding.
    Why does this not work
    "waitpeq %000, %100"
    But this does?
    WAITPEQ data, mask
    data LONG %000
    mask LONG %100
  • AribaAriba Posts: 2,695
    edited 2008-12-01 16:45
    The Assembly instructions can have two formats:
    1) instr destreg, srcreg
    2) instr destreg,#value
    You can't write a literal value as first parameter (destreg), only as second parameter (srcreg), and this value can only be in the range 0..511. These is a result of the way, the bitfields in the 32 bit instruction are allocated.
    For WAITPEQ you can use an immediate value as mask for the first 9 pins but not more, in all other cases you need registers (which have the full 32 bits).
    But mostly you can use the same register for data and mask:
    WAITPEQ pinmask,pinmask 'wait for pin(s) high
    WAITPNE pinmask,pinmask 'wait for pin(s) low
    Andy
    Good explanation Ariba.
    Pliers, basically you need the "#" in front of the %100. As Ariba pointed out you can only do that for values up to 511 (9 bits).
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
    www.tdswieter.com
