Tricky assembly code: Can U tell me what is going on?
Hello,
I'm new using the propeller chip and I need to write a ADC assembly routine but now I'm having some trouble in doing so. My ADC is the MCP3208 but I'm running it at 5V and therefor the drivers for this ADC available at the OBEX do not work for they use a 1-wire protocoll and I need a 2-wire protocol. So, I have come across something that honestly I have never seen before in any Atmel nor Microchip microntrollers in the past: I write the assembly code and it works fine, until I write a 'nop' in on specific position of the code and the code is just frozen. Not it is not a loop error, its just a plain line of code written in between instructions. The code is frozen for 53 seconds and then starts to work again. 53 seconds it how long the internal 32bit counter would take to start from zero and reach its maximum number using a 80Mhz clock so I believe that there is something to do with the system clock. Now for the code:
THIS WORKS
DAT
{Toggle P16}
ORG 0 'Begin at Cog RAM addr 0
getCommand rdlong bits2, par wz ' wait for command
if_z jmp #getCommand
Toggle mov bits, #20
mov dira, Pins 'Set output pins
mov Time, cnt 'Calculate delay time (move 32bit system counter to Time reserved long)
add Time, #9 'Set minimum delay here
loop
waitcnt Time, Delay
or outa, CS_reg
mov bits, #10
bloop waitcnt Time, Delay
or outa, CLK_reg
waitcnt Time, Delay
andn outa, CLK_reg
djnz bits, #bloop
waitcnt Time, Delay
andn outa, CS_reg
nop
jmp #loop
Pins long (|<CLK) | (|<DIN) | (|<CS) 'transform numbers into bit positions and OR them all together
CLK_reg long (|<CLK)
CS_reg long (|<CS)
Delay long 500 'Clock cycles to delay
bits res 1
bits2 res 1
Time res 1 'System Counter Workspace
THIS DOESN'T WORK
DAT
{Toggle P16}
nop
loop
waitcnt Time, Delay
or outa, CS_reg
mov bits, #10
or outa, CLK_reg
waitcnt Time, Delay
andn outa, CLK_reg
djnz bits, #bloop
waitcnt Time, Delay
andn outa, CS_reg
nop
jmp #loop
CS_reg long (|<CS)
bits res 1
bits2 res 1
Can you see the difference? A simple, small, tiny, 'nop' instruction after the 'add'. Is there anything I should know about how the program is written to the local memory in the chip in order to make it work? Any help would be most welcome.
Kind regards,
Alex
THIS WORKS
DAT
{Toggle P16}
loop
waitcnt Time, Delay
or outa, CS_reg
mov bits, #10
or outa, CLK_reg
waitcnt Time, Delay
andn outa, CLK_reg
djnz bits, #bloop
waitcnt Time, Delay
andn outa, CS_reg
nop
jmp #loop
CS_reg long (|<CS)
bits res 1
bits2 res 1
THIS DOESN'T WORK
DAT
{Toggle P16}
nop
loop
waitcnt Time, Delay
or outa, CS_reg
mov bits, #10
or outa, CLK_reg
waitcnt Time, Delay
andn outa, CLK_reg
djnz bits, #bloop
waitcnt Time, Delay
andn outa, CS_reg
nop
jmp #loop
CS_reg long (|<CS)
bits res 1
bits2 res 1
Kind regards,
Alex
