RS-232 to Propeller
Using "Serial to Propeller" circuit given in Propeller Diagrams,Schematics, and Images I have no problem programing the Propeller chip using the standard serial port of my PC. However, when I connect it to the standard serial port of my laptop I get the error message: "No Propeller chip found on any serial ports". Any suggestions on what might be happening?
Check your outputs from the laptop with a multimeter to make sure that it behaves correctly both when the port is closed and when it is opened. You can open the port normally by running Hyperterminal to check it's operation. Also a simple loopback can be used as well to test the hardware. Laptop serial ports are also prone to damage, especially when the laptop is running from mains power as they are not isolated. This could be your problem.
*Peter*
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
O.A.A
--Rich
* I'm at work, so this is from memory, and it applies to the DB-25 connector. Do a Google search for Null Modem Cables.
O.A.A.
there is a trouble-shouting guide about this issue that you can download from parallax.
Did you do all the things mentioned there ?
best regards
Stefan
Thank you.
USBDriverTroubleshooting-V1.0
best regards
Stefan
I have reduced the latency timer setting from 16 to 1. Nothing changed.
I'll summarize the the problem again :
1. I have a PC and a laptop both with standart serial ports.
2. I am using the 3 transistor circuit given in Propeller Diagrams, Schematics and images.
(The DRS and RTS pins shoted.)
3. I have no problem in connecting and downloading from PC.
4. When trying to connect to the standart serial port of the laptop propeller chip is not recognized.
Reducing latency timer settings made no difference.
The port responds properly to other serial devices. No problem in downloading to BS2 chips
using Max232 serial interface. Seems 3.3v is behind this somehow.
Thank you all.
O.A.A.
DTR is normally asserted (logic 0 = +3 to +25 Volts), but the simple transistor Propeller interface requires it to be negated (logic 1 = -3 to -25 Volts).
It is possible that your laptop has DTR permanently asserted, as this saves a level shifter. Typically there is only support for RXD, TXD, RTS, and CTS. RTS can be substituted for DTR if the software also negates it and uses it for reset.
Post Edited (Andrew E Mileski) : 12/8/2008 10:20:06 PM GMT
that should do it I have the same laptop the prop seril port didnt like having the RS-232 port set to hardware control just change it to none hope that helps I built same circuit and just used 2,3 and 5 ground pin make sure you switch 2 and 3 I had to
I am back again. I did everything suggested but it made no difference. As I mentioned last time, I had a suspicion that somehow the 3.3v circuit may be behind this problem. Well, changing to a 5v max232 circuit (with a 1k resistor on Rx pin of prop) solved the problem. Thanks to all replies.
O.A.A.
O.A.A.
