Basic BS2 question. I just want the bs to connect 2 wires together no +5 volts.
Hello first time poster newbie here.
My problem:
Connect one lead from my voltmeter (set on OHMS) for contimuity to the baisic stamp 2 board of education, then connect the other lead to the basic stamp board of eduction. No votage is needed or wanted.
Essentually i just want the stamp to touch the 2 wire leads of the ohm meter·together.
Things I have tried:
A) 1 lead to po and one to VSS. Made po output. Tried making it high and low to no avail.
1 lead from ohm meter to p0 and one to p1. made p0 input, output high low etc. made p1 every possible combination.
c) Pulling my hair out
Any help from the brilliant folks from this forum, will be greatly appreciated.
Cheers,
Radbrad
My problem:
Cheers,
Radbrad
That post took a lot of work out of it for me. It is much appreciated.
Brad Kershaw
