2bitbitmapdemo plus graphics???? — Parallax Forums
sccoupesccoupe Posts: 118
edited 2008-12-01 01:10 in Propeller 1
I am messing with rayslogic's 2bitbitmapdemo.spin and with a little of his help have been able to convert a bmp and display it on the screen properly. Now I want to put some vector graphics over it with the graphics object. I can use the graphics object alone, no problem, but when added to the 2bitbitmapdemo, I get wierd results. A simple line is segmented and displayed all ove the place. Also, if I just gr.clear the doesnt clear the entire bitmap. I have been able to change what part of the screen that it clears by messing with the bitmap_base value needed for the gr.setup. I have also had different result by messing with other gr.setup values but cant get what im lookin for. I need the graphics object to write to the same "screen" as the bitmap is displayed on. Any clues on what im doing wrong? The code is attached.
Thanks all.
Jason
  • BaggersBaggers Posts: 3,019
    edited 2008-11-30 21:52
    That's mainly because graphics.spin is for the parallax tv drivers. you'd need to modify graphics.spin to use whatever display layout rayslogic's 2bitbitmapdemo.spin is using ( i'm assuming top left to top right, then down one scanline and repeat. )
    http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
    edited 2008-11-30 22:09
    Go and search for the Amazing Sand! demo. Dennis wrote it, and basically he modified both the graphics library, and the TV driver to work with a linear memory mapped frame buffer.
    That's probably the closest code that exists for what you want to do. Works on 1 bit per pixel and 2 bits per pixel.
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
  • sccoupesccoupe Posts: 118
    edited 2008-11-30 22:34
    Thanks,· im still digging on this stuff.· What would really do me would be a tool that converted line art bmp's or jpg's onto vector commands for graphics.spin. [noparse]:)[/noparse]· Anyone have anything like this? The graphics demo is very easy to grasp and modify. I probably messed up going with the 2bitbitmapdemo because now I understand how to use two objects but not really understanding how they work "under the hood". So, now I need them to work together and its a road block for the newb.
    Jason
  • RaymanRayman Posts: 16,224
    edited 2008-11-30 22:35
    That's an interesting idea...
    I think it might work.
    But, this line looks wrong:
    ·· gr.setup(20, 128, 96, 40, bitmap_base)
    You don't really want 128 y tiles, right?
    edited 2008-11-30 22:40
    127 y tiles doesnt sound right to me but thats what was used in the graphics_demo.spin, so I went with it.
    edited 2008-11-30 22:54
    Here's what I have in graphics_demo.spin:
    gr.setup(16, 12, 128, 96, bitmap_base)
    edited 2008-11-30 23:02
    Ah yes,· you are correct. I have dyslexic eyes or something from looking at this code for my entire thanksgiving vacation. [noparse]:)[/noparse]
    It looks like I goofed those numbers as I messed around trying to get the line to display correctly. I have this corrected with what im working with but forgot to correct it before I posted the attachement.
    edited 2008-12-01 00:10
    The other thing you'll have to do is start graphics pointing to bitmap instead of "bitmap_base"... That way graphics will draw on top of the bitmap...
    Attached is the code with a couple of changes as well as the picture data file that im using and a screenshot of the screen that I get with the bitmap displayed as well as a line drawn in white with graphics.spin from 0,0 to 50,50. Perhaps this may help?
    Jason
