TV Output on P28-P31?
I'm just curious if there are any problems using the TV output object with pins 28-31. I know these are used for the eeprom and programming purposes and I'm not sure if it can be done. If it can, are there any precautions to take? I'm making a PCB that will use pins 0-27 as general purpose IO pins, but I can't fit the last four pins on it for direct access. So, I figured I would just add an RCA jack on those last few pins and not let them go to waste.
I'm pretty sure that the resistor DAC for the video would create some issues for you.
It's generally accepted that you can use the programming pins *if* what you are connecting is not
attached while they are in use. A switch in the circuit could give you isolation, but
then you would have the added physical step every time you program it.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
No, this is definitely something I would not do.
'Just a few PropSTICK Kit bare PCBs left!
Btw, why does it have to be 28 dedicated to general purpose, why not 24? Hybrid and Hydra use pins 24, so it would be compatible with their tv drivers with no chanes other than clock speed.
In face, why add TV at all, since you're dedicating 28 to GP, people can use their own layout, and can use 12 like protoboard/demo board, or 24 like Hybrid and Hydra.
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
Also, if you're putting it in a 30 pin breadboard, then bring 30,31 down in place of 28,29, that way, you can have rs232 on you're board.
Another thing, Won't you want something like Vss and Vdd bringing to the 30pins? or at least Vss?
