Quick question about VIN on BOE
Sorry for the newbieness of this question. I just want to check that
I'm right before I take a chance of frying my BOE (And the two BS2s
connected to it)
BOE-boost basically just ties in another battery to the battery pack.
Can I do the same thing with a two-AA battery pack fed into VIN on
the appmod header?
I think that'd give me 7.5 volts with six rechargables which shouldn't
be a problem for the BOE's on board regulator.
So to sum it up, by wiring a 2 AA battery pack to VIN and VSS can
I use six rechargables?
connected to it)
the appmod header?
Parallax Engineering
Draw out the circuit that you get when you connect things the way you suggested.
I could describe what you've done, but you should be able to figure it out yourself if you diagram it the way you'd actually have it.
Although I don't understand why it would destroy the batteries. If they are in in parallel wouldn't that mean its just
providing more possible current to the BOE and the batteries will last longer as a result? Or do I have that entire
concept wrong?
I'm having a tad bit of trouble figuring this out (poor imagination I guess). I can't visualize or draw out exactly how
the connection should go. If I connect to the BOE's battery pack in the same place that a BOE-Boost connects, would
that put all batteries in series or would 5 be in series and 1 parallel? Please excuse my lack of understanding.
I feel so dumb [noparse]:)[/noparse]
So, if I had another 4-cell pack I could parallel them the way I said before (connecting to VIN and VSS) with the result
being that both sets of batteries would last longer and no negative side effects... right?
Although that still won't let me use rechargables.
Guess I'm asking my wife for a BOE-Boost this christmas [noparse];)[/noparse]
Never never parallel lithium batteries. Never attempt to recharge lithium batteries without a charger designed specifically for the batteries involved. They catch fire very easily when charged improperly or even discharged too quickly (like short circuited) and they produce an intense, dangerous fire.
Connecting batteries in series is much more common and works well as long as the batteries use the same chemistry system and are approximately the same capacity
