arctangent in Spin — Parallax Forums
arctangent in Spin
SRLMSRLM Posts: 5,045
edited 2008-12-01 03:30 in Propeller 1
How would I go about finding the arctangent of an angle in spin? I've looked at the Float32 object, but I don't want to have to dedicate a cog to it, and I can't extract the assembly code into a form that I can understand. My guess is that I'll have to access the sine table several times, mix those values together some, and see what I get. Any solutions?
  • LeonLeon Posts: 7,620
    edited 2008-11-30 05:15
    You could use a series to calculate it: x - x^3/3 + x^5/5 - x^7/7 + x^9/9 ...
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • SRLMSRLM Posts: 5,045
    edited 2008-11-30 06:34
    Hmmm. I never thought about using non trigonometric methods. I guess I should have done this before, but I looked up on wikipedia. There are quite a few ways to solve for arctangent using non trigonometric methods, mostly involving sums of one kind or another. When looking, one caught my eye (printed below), and it was created by Leonhard Euler. Any relation? [noparse]:)[/noparse]
    In addition to your method posted above, I like this one:
    And this one:
    I'm leaning towards your sum solution, with the logarithmic solution in second. Now, the challenge(for me at least) is to figure out how to do an infinite series on the propeller.
  • RaymanRayman Posts: 16,367
    edited 2008-11-30 11:32
    I've done atn in assembly before using what I think is the standard technique for microcontrollers, i.e., reducing the range to 0 to pi/12 and then using a very good series approximation...
    Unfortunately, my code is somewhat hard to follow, but I found a similar one here:
    http://www.dsprelated.com/showmessage/21872/1.php
    Look at the comments in this section:
    LATN·· TITLE·· 'ARCTANGENT FUNCTION (LONG)'
    00900018
    IHCLATAN······ CSECT
    01800018
    *············· ARCTANGENT FUNCTION (LONG)
    02700018
    *············· 1. REDUCE THE CASE TO THE 1ST OCTANT BY USING
    03600018
    *·················· ATAN(-X) = -ATAN(X), ATAN(1/X) = PI/2-ATAN(X).
    04500018
    *············· 2. REDUCE FURTHER TO THE CASE /X/ LESS THAN TAN(PI/12)
    05400018
    *·················· BY ATAN(X) PI/6+ATAN((X*SQRT3-1)/(X+SQRT3)).
    06300018
    *············· 3. FOR THE BASIC RANGE (X LESS THAN TAN(PI/12)), USE
    07200018
    *·················· A FRACTIONAL APPROXIMATION.
    08100018
    ······ SPACE
    09000018
    ······ ENTRY·· DATAN
    09900018
    ······ SPACE
    10800018
    GRA··· EQU···· 1·············· ARGUMENT POINTER
    11700018
    GRS··· EQU···· 13············· SAVE AREA POINTER
    12600018
    GRR··· EQU···· 14············· RETURN REGISTER
    13500018
    GRL··· EQU···· 15············· LINK REGISTER
    14400018
    GR0··· EQU···· 0·············· SCRATCH REGISTERS
    15300018
    GR1··· EQU···· 1
    16200018
    GR2··· EQU···· 14
    17100018
    FR0··· EQU···· 0·············· ANSWER REGISTER
    18000018
    FR2··· EQU···· 2·············· SCRATCH REGISTERS
    18900018
    FR4··· EQU···· 4
    19800018
    FR6··· EQU···· 6
    20700018
    ······ SPACE
    21600018
    ······ USING·· *,GRL
    22500018
    DATAN· BC····· 15,LATAN
    23400018
    ······ DC····· AL1(5)
    24300018
    ······ DC····· CL5'DATAN'
    25200018
    ······ SPACE
    26100018
    LATAN· STM···· GRR,GRL,12(GRS) SAVE REGISTERS
    27000018
    ······ L······ GR1,0(GRA)
    27900018
    ······ LD····· FR0,0(GR1)····· OBTAIN ARGUMENT
    28800018
    ······ L······ GR0,0(GR1)······· SAVE ARG FOR SIGN CONTROL
    29700018
    ······ LPER··· FR0,FR0············ AND SET SIGN POSITIVE
    30600018
    ······ LD····· FR4,ONE
    31500018
    ······ SR····· GR1,GR1········ GR1, GR2 FOR DISTINGUISHING CASES
    32400018
    ······ LA····· GR2,ZERO
    33300018
    ······ CER···· FR0,FR4
    34200018
    ······ BC····· 12,SKIP1
    35100018
    ······ LDR···· FR2,FR4········ IF X GREATER THAN 1, TAKE INVERSE
    36000018
    ······ DDR···· FR2,FR0·········· AND INCREMEMENT GR1 BY 16
    36900018
    ······ LDR···· FR0,FR2
    37800018
    ······ LA····· GR1,16
    38700018
    ······ SPACE
    39600018
    SKIP1· CE····· FR0,SMALL······ IF ARG LESS THAN 16**-7, ANS=ARG.
    40500018
    ······ BC····· 12,READY········· THIS AVOIDS UNDERFLOW EXCEPTION
    41400018
    ······ CE····· FR0,TAN15
    42300018
    ······ BC····· 12,SKIP2
    43200018
    ······ LDR···· FR2,FR0········ IF X GREATER THAN TAN(PI/12),
    44100018
    ······ MD····· FR0,RT3M1········ REDUCE X TO (X*SQRT3-1)/(X+SQRT3)
    45000018
    ······ SDR···· FR0,FR4·········· COMPUTE X*SQRT3-1 AS
    45900018
    ······ ADR···· FR0,FR2············ X*(SQRT3-1)-1+X
    46800018
    ······ AD····· FR2,RT3·············· TO GAIN ACCURACY
    47700018
    ······ DDR···· FR0,FR2
    48600018
    ······ LA····· GR2,8(GR2)······· INCREMENT GR2 BY 8
    49500018
    ······ SPACE
    50400018
    SKIP2· LDR···· FR6,FR0········ COMPUTE ATAN OF REDUCED ARGUMENT BY
    51300018
    ······ MDR···· FR0,FR0·········· ATAN(X) = X+X*X**2*F, WHERE
    52200018
    ······ LD····· FR4,C7············· F = C1+C2/(X**2+C3+C4/
    53100018
    ······ ADR···· FR4,FR0·············· (X**2+C5+C6/(X**2+C7)))
    edited 2008-11-30 11:35
    Actually, I see I used a much simpler series, only 3 coefficients and two of them were the same...
    Here's my series code:
    sciTrigSeries:
    ·····;store x in RegY
    ····LD IY,#OP1
    ····LD HL,#RegY
    ····CAR FCOPY···;copy float at [noparse][[/noparse]IY] to [noparse][[/noparse]HL]
    ·····;calc x^2
    ····LD IY,#OP1
    ····LD HL,#OP2
    ····CAR FMUL
    ·····;add c3
    ····LD IY,#C3
    ····LD HL,#OP2
    ····CAR FADD
    ·····;store denomenator in RegX
    ····LD IY,#OP1
    ····LD HL,#RegX
    ·····;load c2
    ····LD IY,#C2
    ····LD HL,#OP1
    ·····;multiply by x twice
    ····LD IY,#RegY
    ····LD HL,#OP2
    ····CAR FMUL
    ····CAR FMUL
    ·····;add c1
    ····LD IY,#C1
    ····LD HL,#OP2
    ····CAR FADD
    ·····;multiply by x
    ····LD IY,#RegY
    ····LD HL,#OP2
    ····CAR FMUL
    ·····;divide by intermediate result
    ····LD IY,#RegX
    ····LD HL,#OP2
    ····CAR FDIV
    And, here's my coefficients:
    C1:
    ····db 03Fh····;1.6867629106
    ····dw 0D7E8h
    C2:
    ····db 03Dh····;0.4378497304
    ····dw 0E02Eh
    C3:
    ····db 03Fh····;1.6867633134· ;hmm, same as C1 !
    ····dw 0D7E8h
    edited 2008-11-30 15:39
    Wait, what happened to Beau? I thought that he posted here...
    edited 2008-11-30 17:20
    SRLM,
    I did, but I realized that you were asking about an ARCTAN solution after I had posted an ARCSIN solution, so I removed my post.
    How much accuracy and what kind of speed do you need? This will ultimately determine which method you will implement.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 11/30/2008 5:31:25 PM GMT
    edited 2008-11-30 20:41
    SRLM,
    Here is a polynomial solution that might work... I tested it and it seems to be within 1% or better of the actual ARCTAN radian value.
    The largest error is near 0 deg.
    x ranges from 0 to 100 (<- 0 to 45 Deg)
    Dtheta is in degrees
    Rtheta is in radians
    Dtheta = 619550 * x - 1659 * x * x - 300970
    Dtheta = Dtheta / 1000000
    Rtheta = ( Dtheta * Pi ) / 180
    Beau Schwabe
    IC Layout Engineer
    edited 2008-11-30 22:57
    I think you can do much better with the way I outlined above... You can do the math using the "FloatMath" object, which doesn't use a cog.
    You can get accuracy to 1 ppm this way...
    But, I guess it depends on hou accurate you want to be and whether you want to do an all integer calculation or not...
  • Andrew E MileskiAndrew E Mileski Posts: 77
    From a C math library for fixed point S31.32 I wrote long ago:
    The standard series for atan converges too slowly, doing this instead is extremely fast:
    1st iteration: atan(x) = approximation1 + something1
    2nd iteration: atan(x) = approximation1 + approximation2 + something2
    3nd iteration: atan(x) = approximation1 + approximation2 + approximation3 + something3
    Where an approximation is 2-terms of the standard series: approximation = x - x3 / 3
    The trick is in figuring out how to calculate the "something". If "something" is expressed as an arctan itself, then it can also be approximated:
    1st iteration: atan(x) = approximation of atan(x) + atan(A)
    2nd iteration: atan(x) = approximation of atan(x) + approximation of atan(A) + atan(B)
    3nd iteration: atan(x) = approximation of atan(x) + approximation of atan(A) + approximation of atan(B) + atan(C)
    The final formula is:
    atan(x) = x - x3 / 3 + atan((tan(x) - t) / (1 + x * t)), where t = tan(x - x3 / 3)
    To further speed things up, x is scaled to be centered around pi /2
     * atan x = SUM[noparse][[/noparse]n=0,) (-1)^n * x^(2n + 1)/(2n + 1), |x| < 1
     * Two term approximation
     *    a = x - x^3/3
     * Gives us
     *    atan x = a + ??
     * Let ?? = arctan ?
     *    atan x = a + arctan ?
     * Rearrange
     *    atan x - a = arctan ?
     * Apply tan to both sides
     *    tan (atan x - a) = tan arctan ?
     *    tan (atan x - a) = ?
     * Applying the standard formula
     *    tan (u - v) = (tan u - tan v) / (1 + tan u * tan v)
     * Gives us
     *    tan (atan x - a) = (tan atan x - tan a) / (1 + tan arctan x * tan a)
     * Let t = tan a
     *    tan (atan x - a) = (x - t) / (1 + x * t)
     * So finally
     *    arctan x = a + arctan ((tan x - t) / (1 + x * t))
     * And the typical worst case is x = 1.0 which converges in 3 iterations.
    sll _sllatan(sll x)
        sll a, t, retval;
        /* First iteration */
        a = sllmul(x, _sllsub(CONST_1, sllmul(x, sllmul(x, CONST_1_3))));
        retval = a;
        /* Second iteration */
        t = slldiv(_sllsin(a), _sllcos(a));
        x = slldiv(_sllsub(x, t), _slladd(CONST_1, sllmul(t, x)));
        retval = _slladd(retval, a);
        /* Third  iteration */
        return _slladd(retval, a);
    sll sllatan(sll x)
        sll retval;
        if (x < sllneg(CONST_1))
            /* if x < -1 then atan x = PI/2 + atan 1/x */
            retval = sllneg(CONST_PI_2);
        else if (x > CONST_1)
            /* if x > 1 then atan x = PI/2 - atan 1/x */
            retval = CONST_PI_2;
        else
            return _sllatan(x);
        return _sllsub(retval, _sllatan(sllinv(x)));
    Post Edited (Andrew E Mileski) : 12/1/2008 4:46:09 AM GMT
