SX MCLR 10K resistor to Vdd? Really?
So I'm shocked i can't find anything discussing this when I searched. I'm using an SX28, and have tied the MCLR to Vdd. (+5). This has worked fine, and I've been programming with the SX-key, which also ties directly to the MCLR on my circuit board. All is well with or without the SX-key plugged in.
So I read the datasheet on the SX and it says the SX MCLR should be tied to Vdd through a 10K resistor to run. So I did this, and with the SX key plugged in, the SX does nothing, with the SX key removed, the SX runs. Odd? So I need to be able to plug the SX-key and reprogram the device without removing a 10K reisistor. My question is, so how needed is the 10K resisitor, and is there a better way to do this that I'm missing?
Can you be more specific about what happens when you plug the SX into the circuit with MCLR tied via a 10k resistor? You say the "SX does nothing." Do you mean it won't program and run? It debug? It won't let the SX generate a clock? Are you plugging it in after having programmed the chip an expecting it to run? I'm not sure what exactly is going on here.
Also, download the FAQ and search for MCLR. The pull-up resistor is mentioned a number of times in it.
PeterM
Post Edited (PJMonty) : 11/28/2008 11:44:07 PM GMT
here is more info.....
The SX does not start up, or run the program with the MCLR tied to Vdd via a 10K resistor and the SX-key plugged in. Unplug the SX-key, and the program starts up. Plug the key back in, and remove the 10K resistor and replace it with a wire, and the SX starts up as well.
Attached is a schematic of my circuit. 'Port4' is were the SX key gets plugged in. If the circled part of the schematic is replaced with a 10K resisistor and the SX key is plugged into Port4, the SX does not operate.
(see attached)
Nevertheless, maybe some words regarding the 10 kOhm resistor might be helpful:
For normal operation, it is necessary that the /MCLR pin "sees" high level, i.e. is connected to Vdd.
The SX datasheet specifies the maximum Voltage on any pin being 7 Volt. As long as you can be sure, that this limit will never be exceeded, you might directly tie any pin that requires high level to Vdd.
The SX inputs are protected against overrvoltage by diodes but these diodes can only stand a certain maximum of current. Therefore, it is a good idea to place a resistor between Vdd, and any input that shall be tied to Vdd as this resostor limits the current through the diode in case an overvoltage occurs. As inputs normally have high impedance, they don't sink remarkable current. IOW, the voltage drop across the resistor is almost zero, so the input is savely pulled to high, even with the resistor in place.
Greetings from Germany,
G
