problems with ping
Hi i have a ping sensor sonar thing and im trying to incorporate it into my boebot which already has the ir sensors on it and im looking around the site and not getting any useful information as to should i leave the sensors on there or just have the ping thing alone and have a program for roaming around with the ping so please HELPPPP!
Parallax Engineering
In the Roaming with PING example, you just need to turn the whole BoeBot through the sweep, making sure that it mostly ends up facing the same direction it started in before the sweep. The rest of the code should be pretty much the same. If you don't understand how to do that, you might start with the Robotics with the BoeBot tutorial and work through the examples so you understand about BoeBot movement before you try to do the navigation.
