Could I disconnect the date line between the BS2 and the PC while the BS2 worki
Hello,
I am involed in a project that I have to achieve· the connection with bs2 and the computer wireless
I know that Parallax 433 MHz RF Receiver or eb500 can achieve this,but refer to the BBS,a date
line should be connect to the PC,and I'd like to know if the date line can disconnect
to the PC when the BS2 working.
Thanks in advance, any advice will be extremely helpful.
I'm not sure that I understand the question.· I think you're asking whether the Stamp can be disconnected from the PC after the PC has loaded the program into the Stamp.
If that is what you are asking, the answer is yes, you can disconnect from the PC after loading the program into the Stamp, and continue to run the program without any connection to the PC.
· -- Carl, nn5i@arrl.net
