In circuit programming SX 5V & 3V
jb1311
I want be able to program an SX while it is in circuit but the rest of the circuit can only tolerate 3 Volts. The SX communicates with the rest of the circuit via I2. Would it be safe to use a dual power supply (SX on 5 Volts and the other chips on 3 Volts) and tie the I2 pull up resisters to 3 Volts?
Robert
ALWAYS Unplug your key from your target before you unplug power to your key or your target with this setup.
ALWAYS Plug in your Key power AND Target power before you connect your key to your target.
This is only a problem when you SX chip is not running at the same 5 volt level as your target device.
Depending on how your serial key and target device power up and power down, you could cause your target (SX) to go into cmos latch up, and blow your SX-Key or your target SX. I blew 8 Keys, and half a dozen targets before I found the cause of this issue. I worked with very closely with parallax on this issue, and we found a way to resolve the problem on the USB-Key.
The safest thing is to use the USB Key, otherwise follow the sequences outlined above.
-Dan
P.M. Me if you wish a longer explanation...
"A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
