Frequency — Parallax Forums
Frequency
CenlasoftCenlasoft Posts: 265
edited 2008-11-25 19:15 in General Discussion
Hello,
I was told that I cannot produce a 1 mhz square wave on a BSII. I have the sx28 kit and I was wondering if I could produce a 1 mhz square wave with it using a 50 mhz resonator? Would I used PWM? Any samples would help (circuit and code).
Curtis
  • BeanBean Posts: 8,129
    edited 2008-11-25 16:12
    Assuming you want a continuous 1MHz output use this (you can use any pin I just used RA.0):
    DEVICE SX28,OSCHS2,TURBO,OPTIONX,STACKX
    FREQ 50_000_000, 34_000_000
    OutPin  PIN RA.0 OUTPUT
    INTERRUPT NOCODE 2_000_000
      OutPin = ~OutPin
    RETURNINT
    PROGRAM Start
    Start:
    END
    Just make the interrupt rate twice the desired frequency.
    Note that since this is done in the interrupt, you can have other code running at the same time.
    Bean
    "The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
    www.iElectronicDesigns.com
    Post Edited (Bean (Hitt Consulting)) : 11/25/2008 6:30:09 PM GMT
  • CenlasoftCenlasoft Posts: 265
    It looks easy.
    Curtis
