Help to mouse/keyboard pinout
I ask·to help the mouse connector, so far I was ever using it in my pcb,
some documents draw in confusion, is this correct pinout, view from above
when we use the cad?
Fisio
www.elettronicamente.com
www.usb.elettronicamente.com
Open Office file which contains an index of all Propeller Forum
Fisio
Fisio
IMHO the Clock line is on pin 6, (not 8) in your picture.
Andy
Pin 2 => +5vdc
Pin 3 => no connection
Pin 4 => Data
Pin 5 => Gnd
Pin 6 => Clock
on your picture 8 should be no connection and 6 should be the clock
I am sure because I measured the voltage with
the multimeter on Propeller demoboard,
also the track towards the VGA connector
confirming whether the +5 V,
I am sure even the pin 3 is (-), because it is·connected to
the ground plane
Fisio
Post Edited (fisio) : 11/26/2008 10:25:39 PM GMT
en.wikipedia.org/wiki/PS/2_connector
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
watching the card created by Chip, visible in this message
NEW PROPELLER DEMO BOARD - picture
and analyzing the figure on page 25 of datasheet version 1.1,
I managed to trace the pin connector seen from top view,
·(when you place the components on CAD)
Fisio
