1) Test the bad output pin to see if it can still be used as an input. The input circuitry might work even if you smoked the output circuitry. If your application uses both inputs & outputs, you can still have 15 I/Os and one I.
2) If the pin still reliably switches from 0V low to 0.3V high, you could feed that output into a comparator (LM339 or such, using a 0.2V reference voltage) and use the comparator output instead of the bad I/O pin.
ercocorvair67
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ ·"If you build it, they will come."
joecamaro68, · We have finished·the BASIC Stamp Tester that is available on the completed projects forum, which will test all the I/O pins for input and output functionality. There is a hand full of parts needed and the assembly of the tester, but it is a great tool for anyone using our BASIC Stamp modules. · Also, Parallax offers a 1/2 off replacement policy·for a·new modules if you wanted to get your current module replaced. If you would like to take advantage of this option, please contact Technical Support at 888-997-8267 to establish an RMA number to send the old modules in for recycling. · · BASIC Stamp Tester: http://forums.parallax.com/showthread.php?p=759839
Vin to Vss =
Vdd to Vss =
Rst to Vss =
Let me know what you get?· Also feel free to send me an e-mail at dandreae@parallax.com for additional help.
Dave
Dave Andreae
Parallax Tech Support·
Thanks for the reply. I found the following:
Vin to Vss = 13V
Vdd to Vss = 5V
Rst to Vss = 5V
Dave
Dave Andreae
test:toggle 7
pause 1000
goto test
which makes pin 7 alternately high, then low each second. Easy to test with a DMM to verify output.
ercocorvair67
Parallax posesses power beyond belief.
Believe in it.
BASIC Stamp Tester:
Joshua Donelson
www.parallax.com
