Servo Help
Hi All
New to PBASIC im using a Pro Dev board with continuous rotation servo connected (Shipped with the kit)
using the following code I would expect to see the servo rotate for 3 seconds but the servo will only run
for a second or so. I have linked led to the pulse so I can see, it stays lit but the servo stops rotating.
please excuse me if I’ve missed something silly as im new to PBASIC.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Test"
counter VAR Byte
DO
FOR counter = 1 TO 122
PULSOUT 15,800
PAUSE 20
NEXT
PULSOUT 15,100
PAUSE 20
NEXT
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Test"
counter VAR Byte
DO
PULSOUT 15,800
PAUSE 20
NEXT
PULSOUT 15,100
PAUSE 20
NEXT
LOOP
- Stephen
Applied and it all works fine.
Thanks Stephen.
