comparison code / hlep urgent
HI,
·hope somebody kindly help to teach me how I program the basicstamp with comparison funtion.
I would like to define one default value, then the actual value could compare with the default value, then slowly to change to the default value, then this action should reflect as sound.
for example, the default value is 30 sec. but the actual value is 40 sec. then when the people with 40 sec. value, it should come out with one sound, but after compare,·there is 10 sec difference, hence the actual value could·take·1 step to change to 30 sec. such as·40, 35, then 30, so·so·sound could be as 40 second·"sound", then 35sec "sound", then··30 sec "sound".
I am prety new on program, hope your expert could give me some example or application which with this comparison funtion. Thanks!
Its always easier for us to help if you show us the code you've already written.
Cheers,
Tom Sisk
http://www.siskconsult.com
