GPS
Hello all, I am wondering about the parallax gps chip. How powerful is it? Say I have a robot that avoids collisions. All it does is roam around and avoid obstacles. With a GPS Chip, would I be able to tell it where to go? And while its going there it avoids anything that is in the way?
- Stephen
The use you make of the information is up to you.· You might, for example, use the "where it is" coordinates to calculate a direction and distance to "where you want to be", and if you've got a compass you can then steer to where you want to be.· But GPS doesn't do that; it only tells you where you are -- that is, where the GPS receiving antenna is.
Oh -- GPS can do one other thing:· it can tell you what time it is, in principle within several nanoseconds.· The receiver has to know this in order to calculate the position, but most GPS receivers yield the time information up· to you very reluctantly, and very tardily.· Still, most GPS receivers will tell you the time with only a few seconds' error.
· -- Carl, nn5i@arrl.net
The use of GPS seems to imply the need for a high speed vehicle such as an rc car so that you can drive over football fields but as has been established in another thread there are no obstacle avoidance sensor good enough to support that speed.
So what do people do with the GPS reciever.· I want to buy but I can't find anything to do with it other than build a GPS reciever.· Since those are so common now that does not seem that interesting.
The earth has a circumference(at the equator) of about 24,900 miles, or 131,472,000 feet. Your GPS can tell you where you are within 60 feet (the Parallax GPS seems to do it in about 10-20 in SoCal, USA). Even so, 60 out of 131472000 is pretty good. That's why GPS is best for large distances: because the scale of GPS is so large.
Post Edited (SRLM) : 11/23/2008 6:09:21 AM GMT
Dunno about other people, but I bought my GPS to navigate in my airplane (back when I had one, can't afford that sort of thing any more).· Nowadays it keeps me from getting lost on trips·in my tiny little motor home.· Most of the time, anyway.
The GPS satellites transmit two codes.· The less accurate of these -- I forget what it's called, and I'm too lazy to look it up -- is the one nearly all civilian GPS units receive and use.· The other, more accurate, is called P-code, and it's encrypted.· Equipment that can decrypt and use P-code is rather closely controlled, but can achieve accuracy of the order of fractions of an inch.· I suppose if you had a P-code-capable GPS in your toys you could make them go from one corner of a room to the other without straying into the neighbor's house.
Please forgive that word "toys" -- no offense -- I just can't bring myself to call anything a robot unless it's a lot like what Isaac Asimov wrote about, or at least what Karel čapek wrote about.· čapek, of course, invented the word.
It's easy to determine the direction from which a signal is coming.· Combine that with your current location, and you can plot a line-of-position for the rogue.· Do that from a car, and drive around a bit, and you can get multiple lines that cross.· Then you've got him.· Approach closer, and do it all again (or continuously), and your placement of his signal gets less and less uncertain.· I don't think a Stamp can handle the computational load, but perhaps a Propeller can.
I also found that I locked onto 4 to 6 sats pretty often, and the accuracy seemed to really improve the more sats I had locked.
If you think its fascinating that you can take a couple of parts and stick them on a board, write a few lines of code and then be communicating with (or at least receiving from) a constellation of satellites 12,000 miles away then you should get the GPS module.
