GPS Speed — Parallax Forums
GPS Speed
Jay KickliterJay Kickliter Posts: 446
edited 2008-12-10 20:20 in General Discussion
I'm·doing a Propeller based balloon project. I·want to log both the ground speed and ascent/descent rate.·Does anybody know if GPS speed takes into account of Z axis movement or juist X&Y?
    edited 2008-11-21 15:37
    Z-Axis is included on GPS in the form of altitude, though I can’t say how good the accuracy is. Pretty much all GPS units support altitude (including ours), however high-end units will often employ a separate pressure sensor to help make altitude readings more accurate.
    Parallax Engineering
  • SRLMSRLM Posts: 5,045
    edited 2008-11-21 18:54
    My *guess* is that it doesn't support z axis in the speed measurement. Logically, most applications don't rise or fall quickly enough for it to matter.
    edited 2008-11-21 19:18
    Jay,
    Why not just log the Lat/Lon/Alt coordinates and calculate the velocities later?
  • Jay KickliterJay Kickliter Posts: 446
    edited 2008-11-21 21:45
    Phil, I think that's what I'll do. See, another idea I had was to monitor decent rate, and if it exceeded a certain threshold, that meant that the balloon bursted and should be cut away. I may still pursue that later, but for a first run I should try to keep it simple.
    edited 2008-11-21 21:59
    But if you cut the balloon, then you just fall faster (unless you have a parachute)
    edited 2008-11-21 22:17
    There is a balloon. The whole idea would be to ensure that the balloon remnants don't tangle with the parachute. But, I think I'm over-complicating things. Given a big enough separation, it shouldn't happen. I do have to have a cutdown device by law, in case the ballon doesn't burst at altitude. I started a new thread about that one.
  • sylvie369sylvie369 Posts: 1,622
    edited 2008-11-21 23:24
    I think you mean "there is a parachute", right?
    AFAIK, in these high altitude balloon projects, there's always a parachute suspended below the balloon, to recover the instruments after the balloon bursts. I assume that's the law as well.
    www.kaymont.com/pages/home.cfm
  • kelvin jameskelvin james Posts: 531
    edited 2008-11-22 18:19
    You could do a diy vario / altimeter, it looks like reading it with a propeller wouldn't be too complicated.
    A couple of links to check.
    http://www.sparkfun.com/commerce/product_info.php?products_id=8161
    http://www.pixelproc.net/altivario.html
  • achilles03achilles03 Posts: 247
    Just FYI, you don't need a cut down device if your payload meets certain FAR requirements (under 6 lb, a mass/area ratio below some threshold, etc).
    Dave
