solid state relay + pwm
i need to control a motor in one direction, due to the amp draw and the price of a commercial motor controller, i want to make a controller. the motor im using has a max amp draw of about 390 amps. i was thinking of using a megafet, but cant find a good one, i was wondering if setting up a solid state relay and then using a pwm would be ok, or if it would wear it out
Parallax Engineering
A controled phase angle fired SSR(two SCR's back to back) has great resolution and a couple DC motor controlers i have laying around also use the same technology.
Easier to have one device for the full load current if possible.
You stiil have to take care that the traces (or wire leads) are pretty equal in resistance. You do have to make sure you've got a robust source for the gate drives because they are quite capacitive and you want to drive the gate through the linear region as fast as possible.
One question: you say maximum draw is 390 amps. Is that full load current? If it is, and your going to on-off control, your inrush is going to be several times the full load current.
PS don't forget the fuses!
Cheers,
Tom Sisk
http://www.siskconsult.com
I have worked in industry, including fairly heavy industry, hacking heavy-duty stuff for 25 years. I wouldn't try this.
