Problem using RS-I Serial Interface Adapter
I'm using a BS2 to output ASCII text using SEROUT commands.· It works fine when connected to a PC but it doesn't work for the hardware that I need it to. I suspect the hardware requires the proper RS232 levels.· So I've got an RS-I interface, I'm feeding it +5V and GND (from the Stamp Super Carrier board) and I'm feeding the output of the STAMP's serial port to the T & R pins of the RS-I.· Trouble is that I don't get any output to the PC when I'm testing it.·
When I loopback the T & R pins of the RS-I, I do get characters echo'd back on my PC screen so I know that the RS-I is working properly.
Any guesses?
Any guesses?
· -- Carl, nn5i
