Nuts and Volts #22
Hey guys,
I am trying to implement the 4x4 matrix keypad code, found in Nuts and Volts Column 22
on my BS2. I have the Parallax 27944 4x4 Matrix Keypad, which is identical to what's being used in the Nuts and Volts example.
I copied over the code, hooked the keypad to the BS2 exactly as indicated. When I fire everything up, Columns 1, 3, and 4 on the keypad work perfectly. However, Column 2 is entirely unresponsive. Column 2 on the keypad was verified to be alive and well by connecting it to another pin on the BS2 and getting a response, so I don't believe it's a hardware issue.
Does anyone see anything in the code that could lead to Column 2 not working? I have a hard time getting my head around the error, since Column 2 is the only one that doesn't work perfectly. Also, any suggestions for hardware that might explain Column 2 being the only non-functioning column?
Thanks for your help...
If You Attch. Your code, It will speed up getting some help!,And a schematic jpeg!!!!
_______________________$WMc%_________
· -- Carl, nn5i
I will check tomorrow to verify all pins are working on the BS2.
Parallax Engineering
