Collecting ExpressPCB Propeller boards — Parallax Forums
RaymanRayman Posts: 16,224
edited 2008-11-20 02:07 in Propeller 1
I'm putting some·of my ExpressPCB PCB designs and the others I've found here on my web site:
http://www.rayslogic.com/propeller/PropPCB/PCB_Boards.htm
I think this could really help people jumpstart their designs...
Let me know if you have something else I can put there.· Or, if you object to my putting your posted file there.
And, if you see something wrong with my "Mini-Marx Controller", please let me know because I'm about to order it! [noparse]:)[/noparse]
  • LeonLeon Posts: 7,620
    edited 2008-11-18 20:42
    Here's one of mine that uses a home-made PCB:
    www.leonheller.com/Propeller/
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • fisiofisio Posts: 38
    edited 2008-11-19 15:56
    Thanks Rayman
    Fisio
    www.elettronicamente.com
    www.usb.elettronicamente.com
  • Mike HuseltonMike Huselton Posts: 746
    edited 2008-11-19 17:06
    Thanks, Rayman.
    I have used ExpressPCB in the past, and thy do good work for a reasonable price. Publishing existing layouts gives me a good jump start.
    Again, I thank you.
    JMH - Electronics: Engineer - Programming: Professional
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-11-19 19:06
    I've had pretty good luck with ExpressPCB too and their software is easy to learn. Only downside is that their file format is proprietary and will not export gerbers.
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
    edited 2008-11-20 00:06
    Rayman said...
    Hi Ryman,
    there is an error in the URL of PropDip5.pcb
    and in the URL of Propeller_Express_Rev_F.pcb
    i can't download the files
    Fisio
    Open Office file which contains an index of all Propeller Forum
    Post Edited (fisio) : 11/20/2008 12:21:14 AM GMT
  • RaymanRayman Posts: 16,224
    Sorry, I forgot that my server is a bit anal about file extensions... I zipped up those files and the links should work now...
