I2C pin choices
sylvie369
I'm trying to use an LIS302DL accelerometer with an I2C interface on a Propeller Protoboard. I set it up with SCL and SDA as pins 0 and 1, but I get no response from the device. To see where the problem was, I took it off and set it up on a Propstick, using pins 28 and 29 there: that worked fine. Then I moved the wires over to pins 0 and 1 (and changed the code), and again, no response. I did dig through the various objects called by the program (lis302dlobject and Basic_i2c_Driver) to see if pin 28 was hard-coded anywhere: that didn't seem to be the problem. I did some other trouble-shooting, such as calling readlocation in the Basic_i2c_Driver directly from my own program: same results. It works if I use pins 28 and 29, and does not work if I use pins 0 and 1. This matters, by the way, because pins 28 and 29 are not available on the Protoboard.
So just now I remembered that on the BS2pe Mobo there are only a couple of different pin options for i2c, and I thought maybe that's the case for the Propeller as well. I moved it over to pins 8 and 9 on the Propstick, and sure enough, it worked. That should work for me on the Protoboard (those pins are available and in a good position), but I'm a bit mystified about why. I'd thought that you could use any consecutive pair of pins for i2c. Are only certain pins available for SCL and SDA i2c connections?
Thanks.
