Propeller Freezing when Launching
Hello, I'm working on a test harness to test a BS2 shiftin equivalent function. It uses most of the code from those functions in the BS2 for Propeller Library. Anyway, my problem is that it seems to freeze on the line
·I scoped it when I first started trying to debug, and all that happened was the clock line went low and the data line went low. I am using the following schematic:
I slightly modified the above schematic by adding some current limiting resistors to the I/O pins. The pin count starts at P0 for the top, and works down to P3
·Now, however, nothing seems to happen to the data line and the IO lines. When I comment out the line mentioned above, the program works perfectly. It reads in the data on the line, and outputs a clock signal. The data is all 1s though, since there is nothing outputting information. Any suggestions?
Post Edited (SRLM) : 11/18/2008 4:13:46 AM GMT
out.SHIFTOUT(value, CLOCK_IN, DATA_OUT)
I expected:
Launch the SHIFTOUT in another cog
go to the SHIFTIN
The SHIFTIN provides the clock
I go home happy...
It sounds like when I put in out.SHIFTOUT(...) that it does everything in the same cog that "launched" it.
