Moding an Arcade Machine to a Propeller/hydra. Portrait vs Landscape screen.
I purchased a Mrs. Pacman full size arcade machine a while back and I'm finally ready to start on this project. I will be replacing the existing screen with a "regular" TV. The screen in the cabinet is originated Portrait (on it's side) so if I use any of the existing games for the hydra, they would be sideways. is there an easy way to rotate the graphics? (I'm guess no) and if so what does that do to the resolution. the 19" screen would be more like a 12" tv screen. not good!
I want to keep the arcade machine intact as possible but I see the best option is to physically rotate the screen. would this be your consensus also?
I'm open for other options as well.
DGSwaner
"When in doubt, use C4" - Jamie Hyneman, Myth Buster
DGSwaner
BTW, fix up the MS Pacman and get a different arcade machine to use for your Hydra [noparse]:)[/noparse]
But, other than using that "hardware" trick, the only other way to do this would be with a set that landscape modes in it and rotation. One trick might be to use a NTSC to VGA converter then get yourself a VGA LCD monitor that has rotation and then you can do it like that.
Andre'
