Stamp and 433MHz Wireless Tx/Rx
Hello,
I have built a small sample device comprising of two basic stamp 1 USB modules, one unit a 433MHz wireless Tx and one unit with a Rx.
The idea is when the button on device A is pressed (and for as long as it is held down) the corresponding LED on device B should be lit, it has 4 buttons, and 4 corresponding LED's...
the program on the transmitter transmits the LEDs as 0000 for all low, 1111 for all high etc...
if i have the Tx unit on, and working, and i turn on the Rx unit, sometimes it wont "sync" with the Tx unit and the LEDs will not light, but if i switch it off and back on again it will work...is there any way that i can guarantee that it is syncing or cause the Rx module to try and sync again if it doesn't receive anything for x number of seconds etc?
Its the only way anyone can help you.
Cheers,
Tom Sisk
http://www.siskconsult.com
Have you established communication between the two BS1 and 433MHz modules prior to this project? For example; demo communication from BS1 to BS1 before the addition of other buttons and LEDs.
Joshua Donelson
www.parallax.com
