Most efficient LCD driver?
LCD Debug is a gross offender. I use bin, decf, hex, str, and that's about it. Anyone know what is the most efficient method to drive an LCD for these few requirements? I have a spare port on the 4x driver, configuring that port as an LCD driver would be ideal if there is a way to make use of the same functionality of the above needs without adding cogs. Thoughts welcome.
LCD Debug is a serial LCD driver or graphics LCD driver?
I am working on a driver for an LCD that I will be selling soon. The display is a graphics display though and not a serial display. The LCD driver I am working on will work with graphics.spin so just about any graphics can be drawn on the screen.
If LCD Debug is a serial LCD driver, then maybe you can just narrow down and remove what you don't need.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
It's a modified version of the one in the obex from Simon Ampleman modified to have busy polling and initialise reliably.
Pull my finger!
Post Edited (BradC) : 11/17/2008 5:52:45 AM GMT
I have a nice solution using the spare port on the 4 port so that no new cogs are required.
Yeah, I forgot I can't attach .spin files without renaming them <grumble>
Pull my finger!
Paul Baker
