Comparing Strings
I am looking for an easy way to compare strings in a BS2. The string was read into an array with this command, SERIN LCDin,Baud,[noparse][[/noparse]STR serStr\9]. Ideally I would to use something as simple as, IF serStr <> "bla bla bla" THEN...
Any help would be great!
The easiest thing to do would be to use DATA statements to place constant strings into EEPROM and write a subroutine to compare your variable against a string given its address in EEPROM. You could also write a subroutine to look up a string in a table in EEPROM like:
Bla1 data "BlaBlaBla",0 data "MoreBla",0 i var word j var word x var byte z var byte ' This is called by setting i to the address of the EEPROM string to compare ' It returns with z zero if the match was successful or z non-zero if a mismatch ' If there's a mismatch, i is left pointing to the next string in EEPROM compare: j = -1 ' Start j one position before start of string check: read i,x : i = i + 1 : j = j + 1 ' Get a character and increment pointers if serStr(j) = x then goto check ' Still matching, continue comparing z = x findEnd: if x = 0 then return ' Make sure i points to the next string read i,x : i = i + 1 goto findEndPost Edited (Mike Green) : 11/16/2008 8:07:51 PM GMT
I am new to STAMPs and am using a BS2 for development. It has quickly become obvious I need to move up to the larger STAMPs.
Thanks again.
If you're used to more traditional processors, the 28SX and 48SX chips (and the boards, I love the boards) will run at 50 MIPS and support a real hardware interrupt, you might check those out.
