Need Decimal equivalent of bitshift — Parallax Forums
T ChapT Chap Posts: 4,249
edited 2008-11-14 05:22 in Propeller 1
In the code below, the Vincilum responds to a string as shown in VoiceIntro, where an mp3 on a thumbdrive named 1005 plays on demand.
I am setting up a human voice response system, and have a voice that counts 0 - 20, 30, 40, 100, 200....1000 etc, so that any combination of numbers can be spoken by putting together the fragments. For example, "100.mp3" + "20.mp3" + "2.mp3" + "degrees Fahrenheit" can be spoken in that order to say "one hundred twenty two degrees fahrenheit". Other uses where the system needs to respond with numbers are used as well. The possibilities are up to 1000. I am looking at an efficient way to speak the numbers on demand, without having to set up a method foe each number possibility, but it seems a bit challenging.
Since many of the mp3's have the number "0" in it, I substituted -1 as the end indicator, but the loop never finds -1, there is an infinite repeat.
Furthermore, I am not sure if it did find repeat if it would send the correct string, as it appears that it may send a string with 0's after the string, which will likely confuse matters. So this system is somewhat flawed.
Any suggestions to solve this are appreciated.
Using 4port FDS, port 2
VAR
   byte VoiceData[noparse][[/noparse]15]
PUB VoiceIntro       'This works
     ser.str(2, string("VPF 1005.mp3", CR))   'command to play file  1005 on drive
     waitcnt(80_000_000 + cnt)
PUB SayTemp  | indx       'goes into infinite repeat
   VoiceData := BYTE[noparse][[/noparse]@V70]
   Indx := 0
   repeat
     VoiceData[noparse][[/noparse]indx++] := BYTE[noparse][[/noparse]@V70][noparse][[/noparse]Indx++]
     spk.beep(19, 2000, 200)       'test beep:  detect if looping
   while VoiceData[noparse][[/noparse]indx] > -1                             'Loop until end found
   ser.str(2, string(VoiceData, CR))     'sends string to VMusic2   Vincilum/VLS1033 mp3 player    obviously sends one byte not all bytes
DAT
   V70 byte "VPF 70.mp3", -1
Another idea:
VAR
PUB SayTemp  | indx       'not working
   ser.tx(2, VoiceData)
   Indx := 0
   repeat
     ser.tx(2, VoiceData[noparse][[/noparse]indx]) '   tx(port,txbyte)
   while VoiceData[noparse][[/noparse]indx] > 0                             '-1 goes into infinite loop
   ser.str(2, string(CR))
DAT
   V70 byte "VPF 70.mp3", 0     '  -1 goes into infinite loop
Post Edited (Originator) : 11/14/2008 4:39:37 AM GMT
  • mparkmpark Posts: 1,318
    edited 2008-11-14 00:36
    You're incrementing indx twice here. And in the next line, VoiceData[noparse][[/noparse]indx] hasn't been assigned yet.
    Probably you should take out the ++ from that first line and add a new line that just increments indx:
    VoiceData[noparse][[/noparse]indx] := BYTE[noparse][[/noparse]@V70][noparse][[/noparse]Indx]
    ++indx
    Also, you need to sign-extend byte variables if they're signed:
    while ~VoiceData[noparse][[/noparse]indx] > -1
    Post Edited (mpark) : 11/14/2008 12:43:32 AM GMT
  • T ChapT Chap Posts: 4,249
    edited 2008-11-14 03:31
    Thanks a lot for the pointers. I tried everything above, still got no response, so I bailed on that system. Maybe do case statements, not really any more work to go that route.
    edited 2008-11-14 04:40
    Ok the case statements are a bad idea too, there would be tons of them.
    I need a method to extract each number from a decimal from 0 - 1000, so that I can command individual mp3's to speak each part:
    speak the number 925:
    900.mp3 then 20.mp3 then 5.mp3
    Is there anything similar to bitshift to extract each number?
    edited 2008-11-14 04:53
    Multiply and divide (and modulus) work fine
    a := 925
    x := (a / 100) * 100 ' This is 900
    y := ((a / 10) // 10) * 10 ' This is 20
    z := a // 10 ' This is 5
    That is the ticket Mike! Works like a charm.
