PIR sensor sensitivity
Hey,·
I am try to have my newly revamped robot detect motion to some extent accuratley, problem is it seems to be WAY·too sensitive.· Any suggestions on how to fix this?
I am not for sure but you may be able to adjust your programing and set parameters to make your robot to do what you wish based on an high and a low variable
I hope this is correct and helpful
Badger
Dave
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
As far as what i plan to do with it is to just, well detect motion and use it as an input into various programs.
Thanks all, all suggestions and comments are read and appreciated!
