Cognew in PASM — Parallax Forums
Cognew in PASM
gambrinogambrino Posts: 28
edited 2008-11-14 00:38 in Propeller 1
Hello , i read the Propeller programming tutorial and i played the exercises , and i feel that something i didn't understood it good.
1)Can one cog toggle 2 pins simultaneously ? or i should use the parallel processing?
2)How can i toggle 2 pins simultaneously in PASM ? using cognew ? can i write like this to toggle pin16 and 17 simultaneously ? :
{{ AssemblyToggle.spin }}
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Main
cognew(@Toggle, 0)
DAT
        ORG 0
Toggle  mov dira, Pin
        mov Time, cnt
        add Time, #9
:loop   waitcnt Time, Delay
        xor outa, Pin
        jmp #:loop
Toggle1 mov dira, Pin1
        mov Time, cnt
        add Time, #9
        xor outa, Pin1
        jmp #:loop
Pin long |< 16
Pin1 long |< 17
Delay long 80_000
Time res 1
Thank you for your help
  • HarleyHarley Posts: 997
    edited 2008-11-13 18:19
    I too have that need, gambrino. Here was my approach; probably got the clue from off this forum:
    Using a 'temp' register, I've used this
       xor   temp, OUTA  ' combine with pin states
       xor   OUTA, temp  ' then set/clear for desired output
    Possibly there are better or faster schemes. I'd welcome any myself. yeah.gif
    Harley Shanko
  • AribaAriba Posts: 2,697
    To toggle P16 + P17 simultaneously:
    CON
    PUB Main
    cognew(@Toggle, 0)
    DAT
            ORG 0
    Toggle  mov dira, Pins
            mov Time, cnt
            add Time, #9
            xor outa, Pins
            jmp #:loop
    Pins long 1<<16 | 1<<17   'PinMask (set all Pins to 1 which should toggle)
    Delay long 80_000
    Time res 1
    XOR toggles all Pins which have the Bit set in the Pin Mask. You can toggle 1 to 32 Pins with one XOR.
    1<<16 (or |<16) is a more readable form of writing %00000000000000010000000000000000 but in this binary
    form, you can see how every bit0..31 of the mask corresponds to a pin PA0..PA31 on the Port.
    In PASM all bithandling is done with Bitmasks. Use
    XOR to toggle the bits (pins)
    OR to set the bits (pins)
    ANDN to clear the bits (pins)
    MUXxx to set the bits according the C or Z flag value.
    Andy
