DS2760 Recommended practice
I am working on a project that uses the DS2760 Thermocouple kit. I am using a T-type thermocouple. The installation of the thermocouple into the chamber where I want the measurement has gone together well. The thermocouple wire is then run to the DS2760 which is in its own plastic case. According to the Parallax datasheet and app note the thermocouple wires should be striped and placed in the socket. Is there any reason to not solder them into the sockets on the PCB? My installation is permenant, so I want to ensure it is robust. This is my firs time working with them, so I wanted to make sure there wasn't a reason to solderin gthe wires into the socket.
Over in the Propeller forum I have been working on software for the DS2760 if anyone wants to jump in an give their advice from the software side. I am having trouble getting the calculations to line up in all conditions.
Propeller Software post: http://forums.parallax.com/forums/default.aspx?f=25&m=306775&p=1[noparse][[/noparse]url]
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.tdswieter.com
www.tdswieter.com
Paul Baker
www.tdswieter.com
Paul Baker
www.tdswieter.com
Cheers,
Tom Sisk
http://www.siskconsult.com
