Need help with this Loop. Its not doing what its supposed to
' {$STAMP BS2}
' {$PBASIC 2.5}
'{1 to 6 with a pause 20 is equivalant to 1 inch)
irDetectLeft VAR Bit
pulseCount VAR Byte
pulseLeft VAR Word
pulseRight VAR Word
loopCount VAR Byte
irDetectMiddle VAR Bit
hit VAR Nib
finish CON 4 'Just a constant of if a square is made
turn VAR Nib 'Will increase if a full corner turn is predicted
'measure VAR Byte 'Variable for distance in inches
DO
FREQOUT 8, 1, 41500
irDetectLeft = IN10
FREQOUT 2, 1, 41500
irDetectMiddle = IN0
IF (irDetectMiddle = 0) THEN
DO
PULSOUT 13, 850
PULSOUT 12, 800
LOOP UNTIL (irDetectLeft = 0)
=====more code=======
Basically, it stays in an infinite loop. not sure why at all. Its just a boe-bot with 2 Irs.
Post Edited (Statz) : 11/13/2008 4:39:56 AM GMT
You may want to rethink the whole thing (where the IR detection fits into the movement logic).
You really didn't say what you're trying to accomplish with the program. That helps when you ask a question.
That makes sooooooooooooooooooooo much sense
lol! how simple. I kept revising my code. Thanks, that basically solved the whole problem
Joking of course,
· -- Carl, nn5i
