Power Supply
I'm making a project with a 12vdc motor (came from a hospital bed). It works fine with my big power supply that I use for HAM radio or from a car battery but these are just to big for that. Today, I bought a small 13.8vdc power supply from Radio Shack. www.radioshack.com/product/index.jsp?productId=2103959 When I plugged the motor to the power supply it started to run like a stepper motor with pulse of about 500ms !! Then I checked the output on the scope. When both neg and pos are hooked to the scope it shows 13.8vdc but when I remove the neg I can see the pulse (attached image).
Do you think that I can fix that with a bridge rectifier and a capacitor? If yes can you tell me which parts I need exactly ?
Thanks for your help.
Carl
Carl
Here is where you can find a 10 amp transformer
http://www.mpja.com/prodinfo.asp?number=7846+TR
I hope this helps
··Thanks for any·
Sam
