Need a math trick to avoid using Float obj
T Chap
No cogs to spare but have a decimal to compute.
Reading a temp sensor IC (Max6634), the output is 1 LSB = .0625 Celcius.
The MSB is the sign bit, so I lose it with bitshift left 1. The 3 most LSB's are flag bits that are ignored, so I lose those with bitshift right 3 (or - 07H). In other words, a read of $08 = .0625 celcius.
I need a math trick to produce whole numbers only, the accuracy needs to only be 1 degree.
In the end, this will get converted (as an optional display) to Fahrenheit using what I have found to be a simple conversion:
( (9 * TempCelcius)/5 ) + 32
Any suggestions appreciated.
Post Edited (Originator) : 11/13/2008 3:09:00 AM GMT
PUB ReadTemp i2c1.i2cstart(i2cSCL1) I2C1.I2CWrite(i2cSCL1,TEMPIC + WRITE) 'send device + read mode 0 = WRITE 1 = READ I2C1.I2CWrite(i2cSCL1,$00) 'send command byte, this is the register to act on i2c1.i2cstart(i2cSCL1) 'send new start condition for read I2C1.I2CWrite(i2cSCL1,TEMPIC + READ) temp := i2c1.i2cRead(i2cSCL1, 0) << 8 'get byte 1 temp |= i2c1.i2cRead(i2cSCL1, 1) 'get byte 2 i2c1.i2cstop(i2cSCL1) temp <<= 1 'get rid of D15 MSB sign byte if present temp >>= 4 'get rid of D0, D1, D2 unused status bytes if present 'lcd.gotoxy(0,0) 'lcd.decf(temp, 8)
I hope you've declared temp as a word, otherwise the shifts won't work as you might expect.
Remember that all intermediate results are 32 bits.
To convert 1/16ths of a degree Celsius to Fahrenheit and keep as much resolution as possible, do:
temp := ((9 * temp) / 5) + constant(32 * 16)
This will give you a temperature in 1/16ths of a degree Fahrenheit. To round it to the nearest degree, do:
temp := (temp + 8) >> 4
Pull my finger!
BradC, I thought you were joking, but noticed that you did put that in there, I need to test it to see how it works. I couldn't find an explanation for it in the help menu, I will dig through the thread and look for it.
MAX6634/6635 is a cool chip for temp.
EDIT:
I see what you mean, you meant just use a constant in place of 32 x 16, not some mystery constant that is multiplied by (32 x 16). My bad. Slow in the head sometimes.
Post Edited (Originator) : 11/13/2008 7:21:06 PM GMT
rather than recomputing it at runtime.
