vex sonar ranger
i have a sonar ranger from a vex kit can i get some coding and hookup info for it to connect with the stamp
it has an input wire and an output wire that is seperate from the input
Parallax posesses power beyond belief.
Believe in it.
Believe in it.
Believe in it.
I wish I could decipher the code from MPLAB.. the separate input & output signal lines, should work similar to the Ping, except the code needs to send the output signal from one line, then wait for the detected signal on another.. (Sorry, you cannot place the two on the same line.) Both would interfere with eachother.)
Stephen (Who's crossed Vex & Parallax lines many times.. I don't discriminate by brand.)
i wish i had more of them
the only problem is i use erector sets also which has round axles and vex has square·axels so i had to get the grinder out and square up one end of a round axle to make things work
Believe in it.
Post Edited (Lab Rat) : 11/14/2008 12:29:58 AM GMT
