Using the Digital Pot AD5220 with the Propeller - any need for signal condition — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2008-11-12 19:26 in Propeller 1
Hi all,
I've decided to digitally manage the threshold of a comparator and I'm thinking about using a digital pot, AD5220, controlled by the output of a Propeller. I've read that the AD5220 needs a debouncing circuit for a manual push button device, but I'm wondering whether the Propeller output needs any conditioning so the digital pot won't end up skipping steps and give me a threshold I hadn't intended. So long as the wiring isn't overly long, is there any reason I can't confidently pipe the output of the Propeller directly into the digital pot?
thanks,
Mark
  • LeonLeon Posts: 7,620
    edited 2008-11-12 18:31
    Debouncing is only needed for mechanical contacts. Slow rise and fall times can cause problems sometimes, but the Propeller outputs will be OK.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Thanks, Leon,
    I guessed that was the case, but I wanted some experienced advice like yours before I ordered a bunch of parts.
    cheers,
    Mark
