getting SX Key not found error — Parallax Forums
JoeAJoeA Posts: 33
edited 2008-11-14 01:46 in General Discussion
I'm getting error "SX Key not found on COM4" when I try to program/run my SX Tech board.
Configuration:·
windows Vista home premium 32 bit service pack 1;
Parallax USB to 232 Rev B (C) 2005;
SX-Key Rev F;
SX Tech 2004-1999;
SX28AC/DP-G· 0720;
Assembler: SX-Key v3.2.3;
Setup-SX-Key-Editor-v3.2.3lg;
(or 3.2.9h-beta--see below)
It had been running on XP before I switched to Vista.
I tried installing:
USBDriverInstallerV2.04.06
but got error "this program might not have installed correctly"
and I still got the "not found" errorl
Then I tried installing:
USBDriverInstallerV2.0.0 which I had used under XP.
It seemed to install OK, but gave the same "not found" error.
The Windows System Device list shows
"Ports (COM & LPT) / USB Serial Port (COM4)"
when the Key is plugged in,
and There IS a COM4 radio button, checked, in the IDE Serial Port panel on the Run Configuration screen in the SX-Key software,
but I still get the "SX-Key not found on COM4" error when I try to run, program, or debug.
Finally, I tried installing
Setup-SX-Key-Editor-v3.2.92h-BETA.exe
it said it was installing USB drivers,
but the Windows System device listing show the COM4 driver as:
Provider:FTDI; Date: 5/19/2006; Version: 2.0.0.0;
That gave the same error, even after re-installing USBDriverInstallerV2.04.06.
I am still getting the same error message, and have run out of ideas of things to try.
Any suggestions?
    edited 2008-11-12 19:32
    Has this ever worked or did it just break when going to Vista?
  • BeanBean Posts: 8,129
    edited 2008-11-12 19:39
    Joe,
    · The SX-Key serial version gets it's power from the development board. Unlike the USB version that gets power from the PC USB port.
    · Make sure you have it plugged into a development board with a good SX chip and powered up. Otherwise it will say "Not found".
    Other than that, I would try removing the COM port from device manager and letting your system re-install it.
    Bean.
    "The welfare of the people in particular has always been the alibi of tyrants." ~ Camus
    www.iElectronicDesigns.com
  • $WMc%$WMc% Posts: 1,884
    edited 2008-11-13 02:26
    JoeA
    Go Back to XP:Vista thinks were a bunch of HACKERS because it see's USB in A diff. light....You can make it work w/ Vista,,But why take all that Agerv... That and XP runs faster??????????
    HP,LexMark, and few other Spooler drivers/ along w/ the BloutWare they Add will tie up the USB ports...W/ XP You have better control of this....Vista looks at this as "AUTO UPDATES",,,Not Good
    You'll eventually get the Drivers loaded and working,,Untill You add some more,Or get·A "WindowsUpdate"
    But I Have to admit,The Chess game is cool
    _______________$WMc%____________________
    Post Edited ($WMc%) : 11/13/2008 2:40:38 AM GMT
  • VelocitVelocit Posts: 119
    edited 2008-11-13 04:51
    I've always had to use my virtual machine with XP on it to use the serial SX-Key. Vista was very finicky and would hardly ever program a chip using the old Key. The USB SX-Key, on the other hand, works very well. It's instantly recognized and programs chips every time without problems.
    -Paul
    I had trouble with my Blitz because my power supply was wheezing.· No further troubles with a heftier supply.
