How do I program this light bar?
Hello, I am trying to program this bar to work like KITT (From Knight Rider) scan bar. You know, the red scanner in the front? Anyways, how do I set this up. I have Board of education and BS2.
Here are images of the bar
http://img255.imageshack.us/img255/6886/img0027ca1.jpg
http://img504.imageshack.us/img504/3452/img0028rm6.jpg
A+ A- B- B+
C- C+ C+ C-
The letter represents an LED, the +- represents polarity. I had to add my own resistors. The easiest thing for you to figure out which polarity to use is to use a multimeter with resistor detection (that can tell you if you have an open loop). Find the pairs, and find the polarity.
Except for the package type, it should work exactly like any other LED, except in this case you have 3/4 dozen (or so)
Edit: posting links to pictures is a good idea (rather than plain text), or if the pictures are relatively small (see the sticky in the support forum) you can post them inline.
Before you can hook it up, you have to find the LED pairs (of anode and cathode). Find just one or two for now. Next, write that down, and plug the module into a breadboard over the wide strip in the middle. This isolates each set of pins. Then, using your diagram, hook it up just like you would with any regular LED: see "what's a microcontroller" for more information on that.
Array
Below is the data sheet for a module where the LED pins are next to each other on a single side. Look at page four
My Array
