DS2760 Thermocouple Code needs review - 2's complement problem?
Timothy D. Swieter
I attached my first pass at creating Propeller code for the DS2760 thermocouple kit. I wanted to get the opinions and feedback from the forum before I posted the code into the object exchange.
In general, the code works, but there are a couple times when it does "funky things". I believe that the problem is with the two complement and the math going on. I tried following some of the Basic Stamp demo code, I also reviewed another post on the Propeller forum. In the end though there are times when I get unexpected results. Those results are mostly when the Cold Temperature Junction (CJ) and the Thermocouple Junction (TJ) are the same temperature or more likely when the TJ is lower than the CJ. I have starred at the code and tried several things but I think I am missing something fundamental that is needed in order to make the code more robust.
So, have at it and let me know what you think should be improved. I have a test setup of the thermocouple here that I can try out any modifications if you need me to.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.tdswieter.com
Post Edited (Timothy D. Swieter) : 11/14/2008 12:24:28 PM GMT
www.tdswieter.com
as I don't have a thermocouple-modul laying around here
it is hard to debug the problem
could you provide a table of values some working correct some incorrect
three columms:
1 measured temperature
2 RAW data coming in from the measuringdevice and
3 transformed data
best regards
Stefan
Why of course I can provide data - excellent question. I had to take a step or two back in my code writing to get back to a debugging state where I could output the raw thermocouple data.
I attached a text file. I posted a snippet of the data below. The text file has a column of Thermocouple Voltage (as measured by the DS2760), the Cold Junction temperature (the temp of the IC measured by the IC), the calculated Thermocouple Temp and "time" which is just a half second tick mark for some time vs temp testing I was doing.
It appears the data does not post well in the code block. Open the attached text to read it better. The superious "223" in the TC Temp column are not right. I have also seen it where the TC Temp returns 7 when it is clearly not 7c at the thermocouple. This is happening, I think, when the TC Voltage/temperature is below the CJ temperature. I am fairly certain this is a sign problem. I also think that the code could be optimized too. I would like to learn of any suggestions.
www.tdswieter.com
Maybe if you want to include it in the final driver file.
TJ
I cant seem to upload it right now, Ill try again later.
I don't want to "release" or post the object in the exchange until the kinks of the calculations are worked out. I want the object to work succesfully and reliable for temps from 0c and above. Maybe a future revision can include the below 0c temps, but for now my needs don't need that.
www.tdswieter.com
Post Edited (Timothy D. Swieter) : 11/13/2008 1:54:29 AM GMT
Also my ds2762 chips with nothing hooked up to them show 7 deg c. Not sure if that helps the issue.
Hope this helps.
TJ
EDIT : Do you live in a cold area, the chip surface temperature is 16 deg C, from my Ir temp gun, So Im thinking in the tcvolt ~> 3, is somehow leaving the bit held in 8 in there, causing it to be subtracting 8 from the total temp, instead of moving it out to bit 31 or bit 15.
Im not sure if Im making any sense here.
Post Edited (TJHJ) : 11/13/2008 5:19:41 AM GMT
Nope, I am not in a cold area. When I saw 7c my IC was about 25c and I confirmed that with my IR temp gun as well. I am glad I bought it now.
I will have a look at your upload tonight or tomorrow when I get back to the code.
www.tdswieter.com
I also reviewed your search algorithm. I like it. I can see how it is faster. I thought it could be improved so I sat down and did some changes, but I can't get my code to work at all. I don't think it is is the search algorithm though. Tonight has been a weird night of coding because it seems like multiple aspects of my design is not working and equipment failing and then working. My thermocouple was acting up, my AC controls were acting up. Everything seemed to work and then not work. Even though I am trying to code, test code, test one part of the system at a time, and right now it is the thermocouple, it seems like proven parts were misbehaving. So, I set it aside for now and will get back to it tomorrow or Saturday.
Oh, the thing I tried to improve. I like how the search algorithm was simple. The thing I am a bit paranoid on was the code getting stuck in the repeat loop forever because some unexpected value getting entered as the parameter. So I was changing the repeat statements to be "repeat t from x to y step DDD" coding. This was adding some other checks in the code. I think it will work, but it is slower.......Hey wait a minute. Inspiration!!! At the top of the TJHJ's algorithm a check on the extremes could be done and the code exited there if the parameter doesn't pass that test, then the "repeat until x" style of code would have good reason to complete.
I hope these ramblings make sense.
Another thought, in Spin there is a lookdown and lookup. I think I should research if those operators work with data in the "dat" section of the code. Then maybe the search algorithm can be easier yet.
www.tdswieter.com
Two thought I think your doing one but just making sure.
1. Do a 1/2 range check at the start and will stop it going off the table and will cut the 1st search step in 1/2.
SearchStartVar := -1 if TempMvValue >= table[noparse][[/noparse]min] and TableMvValue < table[noparse][[/noparse]max/2] SeachStartVar := min elseif TempMvValue >= table[noparse][[/noparse]max/2] and TempMvValue <= table[noparse][[/noparse]max] searchStartVar := max/2 if seachStartVar <> -1 ' search here. 'This is where thought two comes in 'It steps up from searchStart var to limit max 'checking by steps of 100 going up ' Instead of backing up 100 by subtracting 100 ' Have the next seach go down by 10. 'until tempMvValue < table[noparse][[/noparse]x] ' Now step back up againit saves a whole step at the end of each loop, Ive got a thought for a floating step option but still working on it.
TJ
www.tdswieter.com
Thought just hit me, Why not just save the last temp, and start the search there? The temp change is very slow of a thermocouple by comparison to the looping speed, so normally we shouldn't make to many steps away if we start the search at the old value with an if then statement.
Pub Search(MvValue) | searchstep, Direction, seachPoint Direction := 1 searchStep := (Maximum+Minimum)/2 searchPoint := Minimum 'EDIT PLACED HERE, Make sure we start at the bottom so the code is more universal 'Make sure we are in the range 1st. if (MvValue > table[noparse][[/noparse]Minimum] and MvValue < table[noparse][[/noparse]Maximum]) 'now repeat while we are in the bounds of the table and havent found it. repeat while (searchPoint >= Minimum and searchPoint <= Maximum ) and searchStep > 0 if MvValue > table[noparse][[/noparse]searchPoint] 'if value > table, and we moving up if direction == -1 ' We just switched Directions SeachStep := SearchStep/2 ' Half our step size direction := 1 ' Same direction of movement dont 1/2 step size SearchPoint := SearchStep + SeachPoint ' Add the same step until we pass over the value then well 1/2 it again elseif MvValue < table[noparse][[/noparse]searchPoint] ' We have gone to far so now we need to step down. if direction == 1 ' We were stepping up, but we over shot it. SeachStep := SearchStep/2 ' So 1/2 our step and go down Direction := -1 ' We were moving down so keep doing that at the same SearchPoint := SearchPoint - SearchStep ' move down till we pass over it again. ' We should exit the loop when SearchStep = 0, but just to make sure. if seachStep == 0 quitwhere minimum is the smallest allowable table value, and maximum is the largest allowable table value,
Post Edited (TJHJ) : 11/14/2008 1:46:04 AM GMT
My immediate problem I think is a 2's complement problem. The problem is occurring when the thermocouple temperature is higher than the cold junction temperature (IC temperature). The problem is occurring in the routine reading the thermocouple voltage though and not in the other processing routines. Here are the results of some testing.
The above code returns the raw register results. The values I get are as follows. These numbers are two's complement, so the large number is more like a small negative number.
Then when I add in the processing such as the following at the end of the one-wire reading.
I get the following results.
The raw results posted first make sense to me. The voltage of the thermocouple being read changes sign. So I understand going from 0 to a really large number which in reality is a small negative number. With the processing results however, the results are going from 0 to a large negative number and I expect it to be a small negative number.
Another post on the forum has referenced this: http://forums.parallax.com/showthread.php?p=682102 The conversation said that the processing being used above may not be accounting for the sign in the two's complement and recommended another method. So I substituted the processing above for the following.
and the results are similar to the other processing results.
So - the problem I want to solve at the moment is how to take the raw value from the DS2760 and get it into a state for processing by the other routines. What I am trying to do is move the value right to get rid of the don't cares in the register. Then multiple it by 15.625 (15 5/8) to get the value of TC_voltage to be in uVolts.
On a side not I am curious why my finger being present by the IC causes the thermocouple voltage to change. Maybe it is the fact that my finger is near the thermocouple ends and heating those when my finger is touching the IC.
www.tdswieter.com
www.tdswieter.com
So here are my suggestions.
Maybe try the hard way sign extend, and if its not negative just push it off the end.
like so.
Or just stuff it in a long, its not as efficient, but it should work correctly.
Any luck?
EDITED : To add 3rd idea.
Post Edited (TJHJ) : 11/14/2008 6:26:12 PM GMT
I think TJHJ has hit on it, I ended up using a temporary variable to make sure we're dealing with 32 bits. Here is some code I had success with. There's probably a more efficient way to eliminate temp1, but this seems to be working.
Greg
PS - the forum seems to be mucking up the code a little bit. That first read goes in to byte 1 of raw_voltage, somehow the left bracket, 1, and right bracket disappeared.
If you have time, take a look at the object and let me know what you think and if you see other areas to improve.
Here is the object: obex.parallax.com/objects/385/
I need to move on to coding other portions of my project now. Since the code is "stable" based on my limited testing, I will leave it for now and come back to it in a couple days.
www.tdswieter.com
Post Edited (Timothy D. Swieter) : 11/15/2008 3:20:03 AM GMT
