Prop Timing diagram? — Parallax Forums
RaymanRayman Posts: 16,461
edited 2008-11-13 02:32 in Propeller 1
I'm looking for the exact timing for the Props Input pins with regard to the clock...
Thought this would be in the datasheet, but I don't see it.
I don't even see any mention of whether the input is sampled on the rising edge or falling edge...
Nothing about a required hold time either...
    edited 2008-11-11 18:45
    INA is sampled during the S stage, and IIRC it is latched at the end of the cycle. There are no setup or hold times other than the signal must be stable at the point it's latched.
    Paul Baker
  • RaymanRayman Posts: 16,461
    edited 2008-11-11 19:09
    What are "S stage" and IIRC?
    And, how do they relate to the rising edge of the clock?
    edited 2008-11-11 19:27
    S is the source stage of the SDIR pipeline, the datasheet describes this, IIRC = if I recall correctly. Maybe I'm missing something, but how does the polarity of the clock matter since it is completely hidden from the user? For example, what is the polarity of the system (ie on which edge does the pipline progress), is it on the rising or falling edge? And does the answer have any practical meaning?
    Perhaps if you provide a little more background on your question, I can understand why the polarity is important. The IIRC statement of my previous post is that I think the latch is in phase with the pipeline.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 11/11/2008 7:35:36 PM GMT
    edited 2008-11-11 20:29
    I want to drive an ADC with the same clock as the Prop... I want to make sure the Prop is going to sample during the time of valid output from the ADC.
    edited 2008-11-11 20:42
    Ah gotcha, I'll have to check. I'll get back to you when I have an answer.
    Paul Baker
    edited 2008-11-12 21:40
    The answer is rising edge.
    Here is the code I used to determine the answer,
    'slave code
    CON
      _clkmode = xtal1
      _xinfreq = 5_000_000
    PUB go
      cognew(@run,0)
      repeat
    DAT
            org 0
    run     mov dira, #2
    loop    mov tmp,ina
            shl tmp, #1
            mov outa, tmp
            jmp #loop
    tmp LONG 0
    'master code
    CON
      _clkmode = xtal1 + pll16x
    PUB go
      cognew(@run,0)
      repeat
    DAT
            org 0
    run     mov dira, #3
            mov frqa, freqa
            mov ctra, ctrav       wz                'z flag now set
            'pin 0 now oscillating at 5MHz
            mov tcnt, cnt
            add tcnt, offset
            waitcnt tcnt, #0
    loop    muxnz outa, #2
            muxz outa, #2
            nop
            jmp #loop
    ctrav  LONG %00100_000 << 23 + 0
    freqa  LONG $1000_0000          '5MHz
    offset LONG 13
    tcnt   LONG 0
    The slave simply copies whatever it sees on pin 0 to pin 1 (which is connected to an LED). The master starts a counter running P0 at 5MHz·which is connected to Xin of the slave, then it toggles P1 in a 5MHz 25% duty cycle. Waitcnt is used to align the second signal to the first, the current offset value aligns the second signal so that it's high period·spans the rising edge of the first signal. When run, the slave's·LED lights up. Setting offset to 21 places the second signal's high period to span the falling edge of the first signal, with this offset the LED remains off. Therefore ina is sampled on the rising edge of the clock.
    Paul Baker
    Thanks. That helps a lot.
