Problem with 27979 LCD display
Way back when I first bought a Parallax product (a Javelin chip) I also bought a 27979 4x20 Serial LCD. I never got it to work with the Javelin, but just assumed it was me screwing something up. Recently while cleaning up mu shop I came across it and decided to try it with the Propeller. Same results
If I set the DIP switches to test and apply power, it shows the proper test message. Then I set the DIP switches for any other setting and try to drive it with FullDuplexSerial and get nada. Zip. Nothing but the cursor sitting there staring at me. I'm a lot more confident of what I'm doing with the Prop, and I'm sure the baud rates are right. I've tried it driving directly from a Prop pin and buffered through a 74LS04 chip to get a 5v drive signal.
Am I doing something obviously wrong, or do I just have a defective display??
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 obj term: "tv_text" panel: "FullDuplexSerial" var pub go | x start pub start | r, sta, bytes, cts, sec term.start(16) term.str(string("Starting display test ")) panel.start(10,9,0,2400) waitcnt(80_000_000+cnt) panel.tx(25) repeat panel.str(string("Hello, world"))
For software I'm using the Debug LCD object. Try that - it should make life much easier.
If you want to use FullDuplexSerial, you might start by looking at whether or not the "start" method (panel.start in your code) is returning "true" when you use it:
I see you're connected to another monitor, so it should be easy to indicate this.
Post Edited (sylvie369) : 11/11/2008 11:12:02 AM GMT
I think it's easier
http://obex.parallax.com/objects/40/
Does the curiosity killed the cat?
