LCD App Mod and the propeller
bambino
http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/53/Default.aspx?SortField=ProductName%2cProductName
Looking at the data sheet for the LCD App Mod reveals that it can be run at three volts. I f I spin a board that would hook the propeller up to the 2X10 header would I have a problem with the push buttons. They were designed for 5 v usage very cleverly to not interfer with bus signals, would dropping the voltage to 3.3 make the tacktile switches incompatable with the LCD bus?
I’m curious how you deduced that the module would run @ 3.3V? The Hitachi chipset specification is for 5V. I can’t see the LCD functioning with less than 5V, though since it is a compatible chipset (not exact) I guess it would have to be tested.
Parallax Engineering
· 5 ´ 8 and 5 ´ 10 dot matrix possible
· Low power operation support:
¾ 2.7 to 5.5V
· Wide range of liquid crystal display driver power
¾ 3.0 to 11V
· Liquid crystal drive waveform
¾ A (One line frequency AC waveform)
· Correspond to high speed MPU bus interface
¾ 2 MHz (when VCC = 5V)
· 4-bit or 8-bit MPU interface enabled
· 80 ´ 8-bit display RAM (80 characters max.)
· 9,920-bit character generator ROM for a total of 240 character fonts
¾ 208 character fonts (5 ´ 8 dot)
¾ 32 character fonts (5 ´ 10 dot)
Hay Chris,
This was the part out of the data sheet that got me thinking!
Only if that display have "HD44780U" controler but not "HD44780S"
Nothing is impossible, there are only different degrees of difficulty.
For every stupid question there is at least one intelligent answer.
Don't guess - ask instead.
If you don't ask you won't know.
If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
Sapieha
Can I be sure what I will get when I order one!
It's for a friend though, so I don't feel to brave about it.
It would be nice to be able to throw in a cheap lcd on my next parallax order.
I have a serial backlit one that I use for debugging, but a little pricey for some projects!
