Javelin uart
Hi All,
I love the Javelin, it packs a lot of punch and is great for prototyping quickly.....However it is far too expensive to build into products.
I have a Uart problem......
I want to write; "Time = 332" as a serial output.
I know I can use uart.sendstring for "Time ="
I also know I can use uart.sendbyte to send individual characters, but how do I take the value of integer "Time" and send it as a string to an LCD? i.e.
What is the Javelin equivelant of SEROUT (, , "Time = ", DEC[noparse][[/noparse]Time})
ANy Help appreciated.
Istha
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
Istha
Adam Smith
char buf[noparse][[/noparse]20]; //to hold string output
int time = 23;
Format.sprintf(buf,"time = %d",time);
generates "time = 23",0 in array buf
My adapted Uart class has a sendString method that takes a char array as parameter
so you can use afterwards
myUart.sendString(buf);
The·Format class is here:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/util/text/
My adapted Uart class:
http://tech.groups.yahoo.com/group/JavelinCode/files/Javelin%20Stamp%20IDE/lib/stamp/core/
regards peter
Can you point me to a good link that explains how to link these libaries?
I
Adam Smith
<Javelin Install Path>\lib\stamp\util\text
(create folders with the above exact names if neccessary)
Use
· ·import stamp.util.text.*;
to use the Format class in your java files.
Rename the original Uart.java to Uart.org
and copy the new Uart.java and UartTools.java to folder
<Javelin Install Path>\lib\stamp\core
Regards peter
