There are several options.
You can setup a Uart and connect to a pc comport.
Running any terminal program you can log incoming messages
to file or transmit file. Due to the limited receive buffer
(255 bytes) on the javelin, a hardware handshake is necessary.
Third option is to use the IDE beta that offers the same possiblity as above
but integrated into the message window (several windows in fact, each can be logged
seperately). http://forums.parallax.com/showthread.php?p=654012
Yes, also Parallax USB datalogger (for usb stick)
and UsbWiz (both SD and usb stick).
These all have TTL level serial interfaces so you
would use Uarts to communicate with these
devices.
How does it work (Like for the USB datalogger)? Do we have to implement the FAT logic on the Javelin side? I'm interested by this function (adding file writing to my application), but don't want to implement all the file system logic...
Is there any way to reduce the number of PINs used by the Parallax Memory Stick Datalogger? Like sharing the pins for transmit and receive? Or will it be better to use the SPI mode and share the Data and Clock line with my other components and command the Datalogger with the Chip Select PIN?
Here are my classes for the Parallax Datalogger.
The class Datalogger.java implements the logical methods,
but requires to be extended to do the physical I/O.
The class DataloggerSPI.java extends class Datalogger.java
to provide the physical I/O.
Class DataloggerSPI_test.java is the main program that
you can download to the javelin.
You could write a class DataloggerUart.java that extends
Datalogger.java using Uarts to do the physical I/O.
I would recommend to use SPI for 2 reasons:
1.·SPI does not take up a VP slot.
2. The datalogger may send unsollicited messages
and this may be harder to detect when using uarts.
Thanks for the files. I will test them and see if it's working fine for me. I also like the SPI approach in order to share the pins with the solar sensor, and so on.
Another option is to use my JideWin Terminal program that also lets you
log incoming messages and transmit files, but it uses the Javelin SIN/SOUT pins.
http://tech.groups.yahoo.com/group/JavelinCode/files/JideTerm/
seperately).
regards peter
Dan
Can this: www.hittconsulting.com/sddatalogger.htm also be an option? Don't really know how to use it, but might be interesting...
JM
devices.
regards peter
Thanks for your prompt reply.
JM
some functions like openFile, readFile, writeFile, closeFile.
regards peter
JM
regards peter
JM
