The 40pin BS2p would be the one to use, that way you wouldn't have to make a lot of changes to the design.
Multi-color LEDs would be an interesting upgrade.
-dan
If you work it like 4 4x4 matrixes (matrices) then you have 4 rows, 4 columns, and 4 layers --·12 output pins.· A little external gating req'd.
Post Edit --··Or one of those 7219s could be used, but that'd be a pain.
Also, depending how you wire it up, it could be "charlieplexed", too, but you'd have to think of it in terms of a 8x8; it's·heavy spatial relations like.
Post Edited (PJ Allen) : 11/10/2008 3:47:39 AM GMT
PJ Allen said...
Post Edit -- A little external gating req'd.· Or one of those 7219s could be used, but that'd be a pain.
You beat me to it.· Several ways to do it with 12 pins, each requiring external gating, but certainly it can be done easily by anyone with knowledge of switching logic.
You could even do it with two pins, using an I2C LED display controller.· One that can handle 8 7-segment ditits with decimal point can basically turn on and off -- guess how many -- 64 LEDs.· That's what it does for a living.· Instead of the 64 LEDs in an 8-digit numeric LED display, turn on and off the 64 LEDs in the cube.
There are one-wire devices, too -- really need only one pin...
-dan
now the only problem is programing
their is another one that's a RGB kit here.·· http://hypnocube.com/order/
thanks
scott
Piece of cake.
· -- Carl, nn5i
http://www.youtube.com/watch?v=lFDcdN47V5s&feature=related
scott
