UController SD Card
I am trying to connect the SD card to the Propeller Proto Board/PPDB board but I have other components on the board which
makes it impossible to place the SD Card breakout board in the P0 P1 P2 P3 and VSS and Vdd.
Can I use another set of PINS like P16 P17 P18 P19 & vss/vdd connections.
Thank you
Siri
Thank you
Siri
SIGNAL - PIN - ALTERNATE PIN
SPIDO - 0 - 16
SPICLK - 1 - 17
SPIDI - 2 - 18
SPICS - 3 - 19
What electronics need - MORE POWER!!!!!!!
Siri
